haydoracin wrote:
We were told white Scotch-Brite and Soft n Scrub.
And that is fine for normal maintenance and for taking care of LIGHT marks on your counter top.
If you have a burn mark, or a deeper scratch, than sand paper, of various grades, is what it takes to get things back to "like new". I have used up to 20,000 grit sandpaper on the windshields of my airplanes to remove the fine scratches from debris in the air. ON a Corian counter top, you always start with as fine a grit as possible to remove the defect and then you use a few lighter grits until you get to the final polish stage. As one poster mentioned, you may want a semi-gloss appearance instead of a high gloss on your counter top. Remember the Corian is probably close to 1/2" thick so it can take a little sanding to remove a deep mark.
