Clay L wrote:
I went on a weekend day. They leave the scales on and you can see the weight in the window. You have to drive with the wheels off the scale to get corner weights. I took a friend with me to guide me so that I was half on and half off. I thought that might be a little more accurate but it has been a lot of years since I took Statics at UT and I might be wrong.
Most scales are not designed to be side stepped that way and it would have been interesting to see if you got a set of numbers, Then drove off and drove back on and see if you could repeat those numbers. If they changed, then how would you know if any of them were accurate? Having scales set up under each wheel set on an axle would give repeatable readings.
