obiwancanoli
Jul 30, 2020Explorer
I concluded the Readybrake not as effective simply because using the brakes on the toad would seem to me to be more effective. I have no other evidence to support my conclusion, but am happy to accede to more knowledgeable sources...
way2roll wrote:obiwancanoli wrote:
OK, here's something else I'm researching... braking systems.
Also happened across a Readybrute with built-in braking mechanism, and concluded it's probably not as effective as what's needed, but again, am a rookie at this... which explains why I'm posting this...
Why would you conclude the ready brute elite not as effective? This is likely the most simple, effective and risk risk free set up you can have. It's a surge brake built into the bar itself and uses your own car's braking system. It's all mechanical so no wiring to fail, no air or hydraulics to fail, nothing to install/uninstall every time you hook up.
38,782 PostsLatest Activity: Sep 10, 2026
