J-Rooster
May 24, 2016Explorer
dougrainer wrote:I don't know what your talking about Doug! My tire guy charged me $20.00 a tire to break down 6 tires ($120.00) and he made no statement about tires running 7 years are longer! He told me that they were fine to run on. And, I had peace of mind. And I ran on them with no problems. I was just sharing my experience and what has worked for me! How's that for research! That's as civil as I can be to you!!J-Rooster wrote:
Trish, to honestly answer your question yes or no your tires need to be broken down off the rim. By breaking them down off the rim your tires can be inspected for inside sidewall damage. Inside sidewall damage is the cause of many blowouts. After your tire expert inspects your tires he or she can make a intelligent decision. I've run tires on my RV with 10 years 2 different times by using this method.
Maybe when people make statements like this, THEY should do research and find out HOW MUCH a Tire company will charge to break down 6 or 8 tires just to inspect. Then reinstall and balance. That may make a big difference in the decision if they are spending hundreds of dollars just to inspect. Also, I doubt ANY Tire Company or expert would state that those 7 year or older tires are SAFE to reinstall and go down the road. They would not be stupid enough to incur the liability of stating those tires are still good. EVEN if they made you sign a liability waiver, the lawyers would still hang them out to dry if something bad happened. Doug
38,766 PostsLatest Activity: Jan 10, 2026
