willi4nd
Oct 14, 2015Explorer
BB_TX wrote:willi4nd wrote:
New to RV's...can I just blow the lines out and be done or is it advisable to pump RV AF through the system also?
As long as you blow out ALL the water lines well, drain all tanks, drain water heater, and pour antifreeze in all P traps you should be fine.
Thats what I was thinking, I have pretty much dug into every corner of my RV to understand how it is built. Have researched online, watched Youtubers and read a few forums.
Along with the traps I think I am going to pour a couple gallons of AF into the gray and black tanks.
Just gotta go by Walmart and pick up the schrader valve fitting I ordered. Also ordered a water heater drain valve
38,769 PostsLatest Activity: Mar 29, 2026
