Dale_Traveling
Mar 14, 2015Explorer II
Low oil will trip the motor side of the generator. The electrical generation side can in effect disconnect if there is a problem with output voltage or frequency. The problem you're going to have is the problem appears intermittent and unless the generator's built in testing will store fault codes determining what the problems is will be difficult.
38,769 PostsLatest Activity: Dec 31, 2014
