dougrainer
May 26, 2014Nomad
PROPYLENE GLYCOL is the boiler fluid Aqua Hot uses. You can buy by the gallon or concentrated where you mix 50/50. It costs about $30 to $40 per gallon. The annual service is
1. replace the fuel nozzle
2. replace the fuel filter
3. check the optical disc when replacing the fuel nozzle
4. check fluid level and top off as needed.
5. no real reason to replace the existing coolant.
6. check all parameters by the pump motor and connections. Doug
