dougrainer
May 26, 2014Nomad
John S. wrote:
You need boiler fluid and it is sold that way. It is for aquahots as the newer ones have the coolant lines surrounded by the water. It is a gras boiler fluid you need.
There is NO water around the coolant lines. It is ALL boiler fluid. Boiler fluid thru the heating lines and boiler fluid in the heat tank reservoir that the Hot Water coil is immersed in. Doug
