dons2346
Jan 30, 2015Explorer
I looked at the pix and the coach sure shows well. I can't tell for sure if it is a '02 or '03 from what I see. I don't remember the couch color being available in '02 and the mirrored back splash in the bath was not on the option sheet. Look at the build sheet in the medicine cabinet and you will have all the serial numbers of installed components. You can check with Cummins and Allison for build dates. You could also use the coach serial number and give CC a call, hopefully they won't charge for the info
I think for '03, CC put in the Hurricane heater that included hot water which the '02 doesn't have.
I see the dinette table has a leg which our '02 didn't have from the factory.
The pax side cabinets were either after market or this could have been a '03 addition. The cabinets were not installed in an '02 from the factory
I would not be afraid of the coach. With 120,000 miles on mine, I can say that I would buy another one.
There are enough ex Country Coach employees out there to keep the coach in top shape. The good techs started their own businesses and all have access to the parts for repair. I haven't heard of anything on any coach that couldn't be fixed.
Buy the coach, join a local CC club and get 10% off parts and have a good time
On edit: After taking a closer look, this coach is a '02. The DW reminded me that our dinette table did have a leg and Davis Cabinets figured a way to eliminate it when we had cabinets done. Also. in '03 CC went to a GE microwave, the '02s had a Sharp. Still a nice coach
