Sjm9911
May 30, 2022Explorer
Bumpyroad wrote:
to "suck " fluid in could be a winterizing system to add antifreeze to system?
city water pressure should push water in the fresh water fill unless that valve is stuck???????????
bumpy
They probably have both, and the winterizing system is the only way to fill it without using a hose. Unless you get a seprate pump as stated above. Not having a gravity fill is not fun.
