bobndot
May 30, 2022Explorer III
What's new isn't always better. I had easy access to my water tank and was able to fill it from inside the rv using a mod that i once viewed.
On a previous rv , i found it easier to cut a hole on the top of the holding tank and use a marine deck-plate to seal it. That gave me the option to fill using a pressurized garden hose or gravity fill via bucket. It also made it easy to clean the inside of the tank. 8” hole with deck-plate.
You could also install an old style gravity fill port and fill tube to the tank. Just cut a hole and seal it like they always did at the factory. They work !
