- prstlkExplorerThis is off topic of the post but had to say - love your screen name. Do you have a place at Priest Lake?
As you can see our screen name is prstlk. We have long used it for many things including our license plate on our motor home.
Our place at Priest is about 3 miles north of Indian Creek Campground. - 2gypsies1Explorer IIIHere's a place for indoor climate-controlled storage in Tucson with their prices:
https://www.nationalselfstorage.com/self-storage-tucson-az-119210 - Mr_Mark1ExplorerCovered is better than nothing. Inside is best. When you are under a carport, the sun will still find it's way to hit the RV somewhere but is protected from the direct sun in the heat of the day.
A carport covered unit will still get very dusty and dirty. Also, you are still not protected from someone bumping into your coach or vandalizing it (depending on how the lot is set-up).
I rent two indoor storage spaces in two different cities year round. One is a full enclosed garage in a RV garage complex of about 100 individual garages (not climate controlled). The other is a HUGE storage building where we are open to each other but the facility personnel will park your coach (they will let you park your own too). I park my own with them helping me. No one but me will will drive our bus unless it's a Prevost service center.
The big enclosed building has partial climate control as it's heated in the winter and has air-flow in the summer months. But, it still has a little less protection as there is a small risk of damage but there are security camera's through-out the building and I have a 50 amp plug-in.
The storage garage that I have rented has a 30 amp plug (almost 10 years now). Even though I rent this garage all summer, I don't use it during the heat of the summer (110-120 degrees at times). I can only run one air unit which is not sufficient in a 45 ft. coach and I'm traveling out of the desert in the summer anyway.
Rent a garage if you can.
Safe travels,
MM. - crassterExplorer IIIf you are going to store it more than 5 years, I would suggest looking at building a metal storage building on your property (if you can). The cost will start getting close. But yes, store indoors.
- Two_JayhawksExplorerFirst ten years of RVing my coach's lived outdoors last ten years indoors. The elements take a heavy toll on RV's outside here in the Midwest. I would almost say even with the upcharge for indoor storage it is the less expensive option.
- SteeljagExplorerI believe under roof is always your best choice to protect your RV / Boat / vehicles !
- Branson_N_TucsoExplorer IIFrom Past experence,you will find out down the line. I stored mine out doors in Tucson and not only the paint, but leather and any plastic inside gets destroyed in a few years. Doesn't take long. Do not waste your money buying a cover.
- John_JoeyExplorerSo is the indoor storage climate controlled?
- obgrahamExplorerUnless yours is a junker, it's money well spent.
- 2gypsies1Explorer IIIIn Tucson, if you can afford it, store it indoors. It gets HOT there! :)
38,778 PostsLatest Activity: Jun 10, 2026
