mtrumpet wrote:
John and Brett,
In either of your designs, have you had any issues with the bottles deforming from the engine heat?
No, by the time the bottle is reached, it is not hot enough to harm the plastic. Same for using the clear, reinforced hose to make an extension-- never seen one melted.
And, that is really the reason for the caution to never allow a drip loop/sag in a crankcase breather hose. In below freezing conditions, the water vapor (a normal combustion byproduct) and condense and then freeze, completely blocking crankcase vent.
