Semi_Retired_Gr
Jan 15, 2014Explorer
PlumberJohn wrote:
Can't help with the gas cap settings,but found out from my credit card banks that if you let them know you are traveling during a certain time period and that you will be using the card multiple times a day at one vendor they will not flag your card. Sure helped on our Calif. to D.C. trip. Used same card 4 times at one gas station, $50.00 limit
so swipe card - pump gas, swipe card - pump gas,and so on. No inconvenience should interrupt RV life.
Not always - I use American Express for gasoline because of the rebate, Had problems on the way to Alaska in 2005 - out in the middle of nowhere and after pumping the gasoline. So phoned before leaving last summer and experienced the same problem! Called and told them I'd phoned prior to the trip and was told they still check! Go figure. At least I was able to use my cell phone last summer - no cell service in 2005 and the station wouldn't let me use their phone.
