MybackyardExplorerJul 31, 2017Creeping slideMy 1997 Winnebago Chieftain has one living room slide. Even when I have the 2 floor latches locked the slide will move out an inch or two. Thoughts on fixing this? Thank you in advance.
smlrangerExplorerAug 01, 2017Slide creeping out, likely weak/failing extend solenoid. HWH sells rebuilt solenoids as does Stuart's in Elkhart, IN.
