My 1997 Winnebago Chieftain has one living room slide. Even when I have the 2 floor latches locked the slide will move out an inch or two. Thoughts on fixing this? Thank you in advance.
Hydraulic or mechanical? Mine is a Power Gear mechanical/gear drive. The drive motor has a brake switch on it. The one on mine got tripped and my slide would also creep out and inch or so until I discovered the brake switch was tripped.
