Tom_Barb's avatar
Tom_Barb
Cross wiring the service pole
today we hooked up to a new service that was wired wrong. The 50 amp breaker was wired red wire in one slot and the white (neutral) was in the other slot.
IOWs phase to ground, not two legs to neutral, to give 240 volts to the coach.
we opened the box on the service pole, corrected the wiring, black to one side of the C/B, and red to the other and the white to the neutral buss.
and ordered a new transfer switch, and new inverter/battery charger for our couch..
beware the new installs.
  • Would seem that the campground owes you something! I always check every time, not just the new ones.
  • RoyB's avatar
    RoyB
    Explorer II
    Here's hoping that was all that got melted down. Have seen bigger lists from other posts...
    I'm pretty sure I would have at least did a VOLTMETER check like indicated on these charts before hooking up to a new service. If nothing else just to double check what the electricians did...
    For 50AMP Service
    For 30AMP Service
    Sorry for your mishap...
    Roy Ken
