map40's avatar
map40
Crossfire tire equalization
Anybody with Crossfire tire equalization in a class c? I tried to install today, none of the brackets work on my 2015 Jayco e450. Any help would be greatly appreciated.
  • I installed Link Manufacturing Cat's Eye on my F550 and did the same as Ron and bolted the valve and monitoring eye to one of the axle bolts and left my center hub cab off. The Cat's Eye system came with 2 sets of brackets. Not sure about the Crossfire's.
  • Bracket is setting on a flat surface. You can see area in picture around bolt circle.
  • ronfisherman wrote:
    Here is what I did on my Super C. Removed the center cap. Then put lug nut covers on all the studs.
    One question: it's the bracket sitting flushed to the axle cover? Did you add spacers?
    Thanks. Unfortunately the brackets won't fit like that in my wheels.
    Anybody else?
  • Here is what I did on my Super C. Removed the center cap. Then put lug nut covers on all the studs.
