othertonka
Jan 11, 2014Explorer
My guess is that the brake pedal has a weak return spring and allows the pedal to bounce when you hit a bump and the pedal will press the Brake light switch which in turn turns off the cruise control. It could also be a combination of a improperly adjusted switch clearance between the brake pedal and the switch and a weak or maladjusted return spring. To test the theory You can hold your foot under the brake pedal so it won't bounce and then drive and hit some bumps
38,782 PostsLatest Activity: Sep 02, 2026
