Nunyadamn
Jun 30, 2013Explorer
I tried the following procedure. When I hold the "off" button and turn the key, the light on the dash blinks once. Then I push the "on" button and the light on the dash blinks once. When I push any of the other buttons (resume, set/accel, coast), the light does not blink. When I am driving down the road and turn the cruise on, then select "set/accel", the light on the dash comes on to tell me the cruise is on, but speed does not hold. I am not sure where to go from here. I would suspect the side of the steering wheel with all three buttons (resume, set/accel, coast) could be bad, but why is it when I push the set button would the light come on - as I am driving down the road?
Did you have the recall done on it ?
recall 05S28. Description: Speed Control Deactivation Switch.
It could be a blow fuse in the recall harness, if you did have it done.
Try the self test, and see what the results are. If you do not get it into self test mode, it could be the fuse in teh recall harness that is blown. The 1st revision of the recall harness was an inline ATM fuse, not sure if the revision 2 was the same. If that fuse is blown, the switch is leaking, and should be checked.
Self-Test Diagnostics
WARNING:
This test is a key on engine off (KOEO) test only that is conducted in park only with emergency brake fully engaged.
1. Enter self-test diagnostics by depressing the speed control OFF switch while turning the ignition key ON, making sure the engine does not start and is not running. The speed control indicator on the instrument panel will flash once to indicate that speed control module entered the diagnostic mode. Five additional flashes at this point indicate a defective speed control servo. Release the OFF switch.
2. Press the remaining switches in this sequence: ON, RESUME, COAST and SET/ACCEL.
If the ON switch is not depressed within five seconds after entering the diagnostics mode, the module times out and the procedure must be started over.
The speed control indicator lamp will flash as each switch is depressed. Press each switch in the sequence immediately after the indicator light goes out for the previous switch.
Note:
There will be a slight delay when the last button is pressed and the lamp flashes.
3. A lamp flash with the last button (SET/ACCEL) indicates that the static test passed. If the lamp does not flash with the last button and there are no additional flashes of the lamp, the switch is defective.
If the lamp does not flash with the last button, and additional flashes occur, follow the chart below for trouble codes:
— 2 flashes - BPP defective, circuit is defective, brake applied, CPP switch or jumper (if equipped).
Source: 2002 Ford F150. Cruise control stopped working.
WARNING:
Note:
38,782 PostsLatest Activity: Sep 10, 2026
