Octanefam's avatar
Octanefam
Cummings ISB 5.9L Turbo Diesel 300hp
I'm new to the diesel engines so how many different Cummins engines do they normally use for RV's? Someone was telling me that the ISB 5.9 is small for a diesel pusher?? So please done rip on me if this is not accurate.
Oh BTW we are looking at 1999 - 2002 Diesel pushers.
THanks
  • Great diesel. Had it on my Dodge Ram 3500 pick up. I used this pick up to haul my 12K pound fifth wheel up and down hills and mountains with no problems and enough power to spare. Now my truck loaded w/o the fifth wheel weighed about 7500 lbs add that to my 12K fiver and you have a total weight of about 19.5K pounds.
    Good luck and happy trails.
  • Ivylog's avatar
    Ivylog
    Explorer III
    The 5.9 is a great LITTLE engine and does well if the MH is not very heavy. The next size up is the newer ISB 6.7L, then the Cat 3126/C7 at 7.2L, then the ISC 8.3L, and then the ISL 8.9L in the 400 HP and less. A ISC 300 HP will have 1000 ft lbs of torque while a ISB 300 HP will have 660 a BIG difference for pulling even small hills.
  • The 5.9L is a good engine I read until you drive on with more power. :)
    If you are driving in the rocky mountains pulling a 20,000 pound trailer you need more power than driving from Houston to Gulf Shores MS for example.
    Some can do a 30 day trip and drive 8,000 miles and others may do a 30 day trip and not drive the MH 80 miles (common here in the KY Lake region) so what is OK engine wise will be determined by usage.
