supercub
Jan 23, 2016Explorer
Cummins Electronic Control Module ???
I have an 04 Fleetwood Revolution with a Cummins 8.3 ISC 350hp engine. I took it to an RV shop because I was getting a check engine light. They determined that the ECM was bad. The local Cummins shop had one and they did the reprogramming of the new unit. The trouble is, the odometer in the motorhome went to zero. It does record the mileage when I drive, but instead of showing around 40,000 miles, it's showing a few miles LOL. Took it back to the RV shop that did the work, and they have contacted Cummins. Cummins says the ECM has nothing to do with the odometer mileage in the motorhome. So, the local RV shop is trying to track down more info. Anyone have a similar problem, or any ideas?? Thanks
Brian
Brian
