dougrainer
May 17, 2014Nomad
Ranger Smith wrote:
You mean they can't attach the new to the old and pull it through while pulling out the old one. Like snaking a wire. Sounds like they just didn't want to do it
You obviously have never looked at a RV pusher Diesel chassis. The wires and hoses are run BEFORE they complete the chassis build and the RV maker then installs either foam or a heavy silicone type sealant at various points along the C channel from front to rear that makes it impossible to use a original wire or hose to snake it thru. ALL the hoses and wiring is also wire tied about every 18 to 24 inches from front to rear. Doug
38,777 PostsLatest Activity: May 24, 2026
