SnomasExplorerMay 17, 2014Cummins is not able to replace heater hoses!I took the MH to Rocky Mountain Cummins yesterday and they said there was no way to replace the 2 heater hoses that run front to back on our Spartan chassis. The hoses run thru the chassis tubular ste...Show More
jwyomingExplorerMay 17, 2014had nearly the same problem. solution was to run a smaller diameter copper line thru the old hose and reattach with new ends.
Related ContentWater Heater Replacement RecommendationsReplace insulation inside heater column.Replacement Lights for TTCummins Hit with 1.7Billion for Emissions Defeat DevicesAtwood water heater problem
