dougrainer
May 17, 2014Nomad
Snomas wrote:
Doug, The hoses run thru enclosed rectangle tube steel framing, Spartan did not use open C channel.
I have never looked at a Spartan, my comment was for Freightliner and I assumed Spartan was the same way. Then the new hoses would have to be run and attached on the inside of that boxed channel. They would be seen if you looked inside, but that is not a problem. Doug
38,777 PostsLatest Activity: May 24, 2026
