glamisorbust
Nov 30, 2020Explorer II
My brother and I spent about half of the day trying to diagnose the problem. I'm pretty sure at this point we know we have a bad ECM. There is definitely constant power there, and the switched ignition works as it should.
We got a wiring schematic from Freightliner south carolina, and traced out all the wires. The lift pump still has no power, indicating the ECM isn't letting the pump run. I have put a battery directly on the lift pump to see if it would fire. With 15 PSI the engine doesn't even try to fire. Just cranks.
38,782 PostsLatest Activity: Sep 10, 2026
