et2's avatar
et2
Cummins ISB 6.7 360 hspwr normal engine temp range
Watching our year old MH temp last night coming home from vacation and I noticed it running at about 201 - 210 mostly at 205 degree. Now it ran going during trip out about 198 - 201 but it was cooler outside, yesterday was 86 degrees - about 10 degrees warmer than the trip out.
The fan kicked in around two times cooling quickly to 192. My question is what are you other people seeing with this engine and normal operating temps? It just seems a little hot. According to Cummins it's within normal temps. Fan on is suppose to be around 212 - 215 and engine shutdown at 220.
So I'm curious if it was hotter in outside air temp say in the 90's am I to expect much higher engine temps or a fan on constantly? The next worry would be mountain pulling in hot temps.
Thanks
