MarcW
May 20, 2013Explorer
Ivylog wrote:
My lift pump only runs for 30 seconds before it shuts off. How did you come up with "engine comm error"? Do you have a code reader? Before I'd let it be towed, I'd be unhooking the batteries every 5 miles if necessary to get to Cummins.
Thanks Ivylog... The repeated 30 sec shutoff on the pump seemed normal to me too and why I'm questioning the lift pump being the problem.
I get the engine comm error readout on the LCD screen in the speedo where it normaly says "engine not running" when the key is turned on before you start.
I don't have a code reader and wouldn't start to know how to use one if I did. The tech on the phone said they would be bringing that equipment when the come out.
Also... it's a '07 with a '06 ISL 400 and that "reset" only worked once. Haven't been able to do it again.
38,778 PostsLatest Activity: Jun 10, 2026
