YC_1
May 23, 2013Nomad
The large relay can run very hot to the touch. Mine draws 1.5 amps so is like having a 20 watt bulb running. The contacts inside are notorious for failing. I am on my third relay in five years. I am beginning to believe the relay should be changed out like a fuel filter as part of regular maintenance.
38,780 PostsLatest Activity: Nov 22, 2015
