FrankK's avatar
FrankK
Cummins misfire when turbo boost above 10 psi
We own a 2004 Holiday Rambler Scepter with the 350HP Cummins turbo engine. The motor home has less than 30K miles on it.
While on the road yesterday, I encountered a problem whereby the engine starts misfiring if I increase throttle to the point where the turbo boost goes above 10psi. It runs fine at idle and under light acceleration.
It seems that the list of possible causes could include:
bad fuel (but why does the problem show only when under boost?)
fuel supply problem (clogged line, filter, etc.)
air supply problem (clogged filter, turbo problem)
ignition problem
If you have experienced this problem and have a checklist or diagnostic procedure, I'd appreciate any help. I doubt that I'm going to find a Cummins dealer open today that would be willing to look at it.
Thanks in advance.
Frank
