Dougjpr's avatar
Dougjpr
Cummins question
Been looking at used DP coaches for a bit, to get an idea about who has what and which models we should be narrowing our search down to.
Most of the units have Cummins engines (which is not a problem or a surprise).
Are all Cummins engines painted red?
Found a 2005 Mountain Aire with the ISL 400 and the engine was black. Does that mean anything? The years we are looking at are 2004-2006, so most of the units have the ISL 400. Also, was there a recall on the ISL 400 in those years? If so how do you know if the unit you are looking at was affected and repaired? I'm thinking engine ser. # sent to Cummins, but not sure.
Any info is appreciated, thanks
Doug
  • Wives tail....as I've not seen older Cummins..Cummins with DPF are red...older Cummins are black..again, heresay
  • Doug, yes you are right... not all Cummins engines are Red. I've seen Black before too but I've never heard of an explanation.
    It has been mentioned that there was a wrist-pin issue with certain engines in the years that you are showing. A call to a Cummins facility will confirm.
    Good luck,
    MM.
