concord_05
Jul 23, 2019Explorer
Curb weight
We are trading our class A for a 2016 Forest River 2401w with the Mercedes Diesel engine. We tow a 2008 Jeep Grand Cherokee 4wd which has a curb weight of around 4600. Our new rig is rated to tow at ...
way2roll wrote:dbertheau wrote:way2roll wrote:dbertheau wrote:road-runner wrote:dbertheau wrote:The 11,030 number is the GVWR, not the curb weight. The sum of the curb weight, passengers, water, fuel, and any supplies is supposed to be under 11,030. Over 10 years of comparing notes with other Sprinter class C owners, I've not found a single one who has weighed their rig loaded for camping, and not being at least a couple hundred pounds over GVWR.
Curb weight is significantly less than 11,030.
You are correct (others on this forum who like to give advice are clueless on the concept). 11,030 is the GVWR...as defined by Mercedes for their Sprinter 3500 extended chassis. RV manufactures purchase these chassis and need to build their coaches on the chassis staying below that weight rating enough that passengers and cargo are below 11,030.
I've removed some items that are not important to me to further reduce the curb weight. My loaded camping weight is indeed below 11,030.
How much lower? and even at 11,000 with a 5k toad you are still over the 4,200. You'd have to be at almost 10,000. I am betting you aren't.
Sir, you don't know me, you know nothing about Sprinters or you would not make statements that Mercedes under built their brake systems and under built their frames. You state GVWR as actual weight of the vehicle and advice folks that they should know facts.
Please don't comment on my posts anymore.
it's simple, numbers are numbers, you are over or you aren't. You are over. Simple.
