timmac
Oct 31, 2014Explorer
lbligh wrote:
Everything you have said about your modifications is simply your opinion and not that of any factory ratings. What is your chassis stated PSI steel rating on the frame rails? My guess is you have no idea.
Safe travels.
36000 psi rated frame, as to your link Ford says its good up to 22000 GVWR and mine is only 20500 GVWR, so I still have a extra 1500lbs safety margin.
And the towing capacity is set by Fleetwood not Ford because Ford has no idea the weight of the RV box going on chassis, like I said on another post my setup is about 2000lbs lighter than other 35-36 foot models with the same frame.
I am maxed but no way am I over weight..
38,769 PostsLatest Activity: Dec 31, 2014
