timmac
Oct 31, 2014Explorer
Here is pics of my added frame extension for more strength and higher towing capacity, its the 6x3 tube slide into the Fleetwood frame all the way to Ford frame, also has three 4 inch round tubes welded to extension and to hitch and to Ford frame, note the large round tube is welded to hitch in 1 pic and the whole thing slides into from back of motorhome, yes some fiberglass was cut to slide it in.
The Fleetwood C channel is weak and that's why its only rated for 5000lbs towing, this also stops the wiggle in back from heavy loads.
38,769 PostsLatest Activity: Dec 31, 2014
