timmac
Oct 31, 2014Explorer
lbligh wrote:
You need to look again. Those are 2014 specifications. I don't believe your coach is a 2014? The specifications change all the time.
Just trying to educate you on how ratings are set and NOTHING you do can increase GVWR. Sorry... those are just the facts.
Safe travels.
Well what do we have here Mr Lbligh..
I went and looked at 2007 Fords F-53 spec for my weight rating and towing rating and you are right, Ford did set the towing weight, but holy molly Ford says my GCWR/Trailer is 26000 lbs and max towing is 5300 lbs but Fleetwood listed GCWR/Trailer at 25,500 lbs and towing at 5000 lbs..
So with that said I am better off as to Ford and might not even be over weight..
Lets here what you have to say now..
Here is a link, go check it out..
To help you out mine is the 208 chassis GVWR 20,500lb, open link for 2007 F-53 and scroll down to page 3..
https://www.fleet.ford.com/truckbbas/topics/2007/specs.html
:R
38,769 PostsLatest Activity: Dec 31, 2014
