timmac
Nov 01, 2014Explorer
lbligh wrote:
And the hitch rating is??????? And your Federal Certification label says???? My guess is, a 5000 lb hitch/receiver and using your numbers, a 5800 lb trailer. So, it looks like you exceed the rating by 800 lbs,
Nice trailer.
Safe travels.
I was throwing more weight on all my numbers and I still came under the specs.
My trailer/jeep/boat most likely weights under 5500 lbs, Jeep weight is 3700lb, trailer weight 1500lb and boat weight at 275lbs adds up to 5475 lbs, also note my hitch has been reinforced with the frame reinforcement, did you note that.
I back yard engineer recertified my hitch to 7500 lbs..
38,769 PostsLatest Activity: Apr 24, 2002
