Sprig
Nov 04, 2014Explorer
timmac wrote:
Like a few others, I just am uncomfortable with that amount of drop.
Take the drop down part that you have on hand and have your welder guy add four gussests to it.
Add two small ones to the top, and two larger ones to the bottom.
If you want to get MORE confident, weld two 1/4" tabs to the receiver assembly, just like on a Jeep for attaching a D ring.
Then get two simple pieces of steel, with two holes, one on each end. Bolt the steel pieces from the bottom hole of the drop down to the new tabs.
What you have already might be fine, but I can't tell from just the pictures.
Even so, I think if it were MY rig, I'd do what I suggested above. If this is unclear in anyway, I'll try to add more detail.
Have FUN!
38,769 PostsLatest Activity: Apr 03, 2026
