I have the Currie baseplate on my '09 jk .. I use the ready brute elite (brake included) if you go this route make sure you get the blue ox clevis ... the demco do NOT fit ... I had found on Currie's web site that certain demco tow bars fit ... so I ordered the demco clevis ... but ready brute was super to work with.. immediately shipped me blue ox clevis... the blue ox is tight on the passenger side so I used a 8 inch sander and took the paint off the center finger of the aluminium clevis and it fit perfect
The Currie baseplate may require a little triming of some non-structural frame (mine did not) and if you want to run wires / cables through the baseplate ... get extra drill bits... that plate is thick ... I did have to use a big screw driver to line up the holes when Installing.. took me 4 hours to bolt in the baseplate..
Private message me if you have any questions.. or I can send pics
