tatest wrote:
How much of that stuff might you consider hang in front of the MH, if a weighing shows it to be light on the front axle? A front receiver hitch can be a starting point for carrying a useful load up there.
I've considered that. I wouldn't use a front hitch, I'd do the same thing I'm thinking about for the rear: remove the bumper and fabricate a replacement bracket/rack that bolts right to the frame.
My biggest concern with this idea is cutting off airflow to the radiator. I will be using this rig almost exclusively in the desert, between May and November.
