Off_Grid_rExplorerMay 11, 2013Custom Portable Propane Soft Tub!Im working on A Custom Portable hot tub for taking on the road traveling. I have a Soft Tub T300 and have gutted the lid to upgrade insulation to R-max Foam board insulation to increase Efficiency and...Show More
jhilleyExplorerMay 12, 2013Will the ShurFlo pump work with hot water? There are 12 volt hot water circulating pumps available.
Related ContentPortable Propane Fire PitsWhat Portable Propane Gas Grill Do You Use?20# portable propane tankDyna-glo portable propane heaterReplacement Seals/O-rings for Portable Propane Cylinders?
