The Ford dealer says there is no adjustment on the rear axle. He said the thrust angle is within specs. He said it can be off as much as.050 mine is off .042 When you are behind the rig as it drives down the road you can see the rear bumper is off 12 in hes from the front bumper. You can actually see the whole driver side of the coach. I think in addition to the thrust angle being off these fools built a out of rack and unplumb box. Is a bunch of other problems too but I won't bore you. It's funny because I want others to read my post and stay away from this company. Unfortunately as I read other people's post prior to my purchase I didn't listen to them. I figured it's probably just a bunch of whiners, surely all that coaches can't be bad.
Marc DeNardo
