10forty2
Aug 10, 2018Explorer
ricelake922 wrote:
To Stuckin Tracy - I need to cut off the voltage to my chassis battery because the battery is not holding a good charge when plugged into shore power enough to turn over the engine. I am at a RV park currently and I am placing a trickle charge on the chassis battery to fully charge it and for that I need to use the disconnect for the chassis battery. I had an eco charger but it is not currently working.
If it helps any, I have a trickle charger hardwired into my chassis battery and plugged into an outlet inside the RV. When on shore power or when the generator is running, it keeps the chassis battery topped of and ready to crank. I only turn the main battery switches off when storing for the winter without being plugged into shore power.
With that said, one quick way I determined which switch turns off the chassis power....the auto steps are connected to the chassis battery on my rig. I turned off a switch and when the steps didn't retract, I figured I had the right one!
