tatest
Jul 20, 2016Explorer II
Should be no studs (that's wall framing) nor joists. Winnebago roof construction is a foam core sandwiched between Filon and luan, dropped onto a welded aluminum frame. If there are frame cross members, they will be on the ceiling side of the sandwich, let into grooves in the foam.
That's also what the AC ducts are, grooves cut in the foam. One channel runs forward from the AC, the other runs back, location of outlets shows where the ducts are.
Wiring is routed in the roof by being set into grooves before the sandwich is glued together. Winnebago usually builds harnesses to cover all the options for a given model, so if there is an optional powered ceiling vent, there should be power to the usual location for installation.
Check out the brochures and wiring diagrams for the equivalent Minnie, Outlook or Access of the same model year, to see if there was an optional vent in the area you want one. Brochures and schematics are available online for the retail models, but not for the rentals.
