RJL
May 04, 2013Explorer
Old-Biscuit wrote:I checked for water in the compartment where the pump is located. No water. I also cleaned the filter for the water pump.
Fresh water tank has water? Yes
Do you fill fresh water tank via gravity fill port OR do you fill via a 'water panel' in compartment? Gravity Fill
Water in tank.....
IF you have the water panel.......check that valving is not lined up to fill. N/A
If it is pump will just round-robin water from tank back thru valve to tank I'm not sure what you mean
The other things to check are cracked fittings on suction side of pump, the bowl with filter on suction side and suction line.....any leaks/cracks will just draw air into pump.
Thanks for the suggestions. I cant help but feel there is a shut off somewhere for the pump. It pumps air through the lines but not water. I just cant find it. When hooked up to my hose (city water) everything works as it should.
38,766 PostsLatest Activity: Jan 10, 2026
