ccathey's avatar
ccathey
Damon Daybreak Towing Capacity
We are looking at purchasing a 2003 Damon Daybreak 3285. It has the Workhorse 8.1 liter with the GM 4 speed. I am trying to figure out if we would be able to tow 4,000 lbs with it. It is a P32 chassis. I found the brochure for it online and it shows that it came with a 3500 lb hitch. It also shows that the GVWR is 18,000 and the GCWR is 21,000. The hitch that is actually on the RV is a 5,000 lb hitch.
What weight should I be able to safely tow?
I am attaching the link to the brochure that I found online.
https://thormotorcoach.com/media/documents/2003_daybreak_print.pdf
  • Thank you guys for the information. We will get it weighed and see where we are at.
  • This has been on here before, but here it is again.
    Tow rating is the lower of:
    1. Coach's hitch rating.
    2. Coach tow rating.
    3. Chassis tow rating (sometimes different than the coach's).
    4. The difference in weight between the coach's GCWR and the coach's actual weight when ready to tow.
  • ccathey wrote:
    We am looking at purchasing a 2003 Damon Daybreak 3285. It has the Workhorse 8.1 liter with the GM 4 speed. I am trying to figure out if we would be able to tow 4,000 lbs with it. It is a P32 chassis. I found the brochure for it online and it shows that it came with a 3500 lb hitch. It also shows that the GVWR is 18,000 and the GCWR is 21,000. The hitch that is actually on the RV is a 5,000 lb hitch.
    You'd have to weigh it loaded and subtract that number from 21000 to see where you're at, but if you assume Gross for everything, you're probably still OK. Sounds like it's not very long and doesn't have much of a wheel base, if it's limited to 3500. Usually the tranny will suffer first, on a P30 chassis, if anything.
    Now, having said all this, I'm not saying that you should go over on anything, but will say we pulled more than a ton over all over the country, with no real ill effects and just had to watch tranny temps. on long 6% grades. Pulling over and using low gear at 25mph gives a 4L80E tranny 25% more pulling power and things like this aren't taken into consideration when doing the specs. Also keeping your speed down to 55mph for shorter wheel bases aren't considered either. For the most part, we never even knew the toad was back there and until we got into those very long steep grades, I mentioned and all these specs. don't even come into play on the flats and rolling hills.
    Now with our present coach, we're a good 10K lbs. under for towing cap, so those days are over, anyway.
  • From the info you have given the answer is no.
    Gross vehicle weight rating is 18000
    Gross combined weight is 21000
    you have 18,000 plus 4000 = 22000 combined
    1000 over the limit.
    But what you really need to do is weigh the Motor home loaded for a trip and see what it really weighs.
    The loaded weight of the motor home needs to be less than 17,400 with everyone and everything on board that you plan to take in the motor home.this includes your pet(s) and toothbrushes etc. Depending on what you tow there may well be 600 pounds tongue weight on the hitch which is why I say 17400
    then you need to add the gross weight of the motor home to the gross weight of the trailer (etc) and that needs to be below 21000
    NB; Correcting early error; the laden weight of the motor home has to be less than 17000 if what you are towing is 4000 pounds in order to stay under the 21000 Gross combined weight
