Rickieblue's avatar
Rickieblue
Damon Escaper Windshield Issues
I have a 2000 Damon Escaper that sometimes will pop the windshield at the top outside corners. I have broken 1 windshield and had it replaced. The only thing I can think is that there is some bracing issues under the front cap but can't verify that. Anyone have any ideas? Thanks for any ideas!!
1 Reply
  • The same thing happened to ours about a year ago. I was told that sometimes the manufacturer cuts the opening for the windshield a little bit to large. I was also told to keep that from happening again I needed to be more careful when leveling so that the frame doesn't flex.
    Now when I level, I plant all 4 jacks firmly on the ground with just enough pressure to slightly feel the coach move. Then I raise the coach with whichever pair of jacks is needed to get the coach level.
    This seems to be keeping the frame from flexing, because I haven't had an issue with the windshield since I started leveling this way.
