wantobefree's avatar
wantobefree
Dang! What a Trip
Well I took everyones advice and got a 1997 Southwind 35W Ford F53. A nice clean lightly used, well equiped unit with all the sevrice records with only 39000 miles.
Everything worked as it should, even the ice maker. I wanted a 38 foot American Eagle, DW said NO. So I set about going over the coach with a fine tooth comb, finding every little thing that could cause a problem.
We took two short trips to local RV parks to make sure all systems were go for our first long outing. Everthing went great, no problem at all. Had all tires checked, paper work
said all six were installed in 2013.
We were going to leave at 6:00 am, the Southwind didn't start, generator didn't start, all batteries showing 12.8 volts. Found loose ground wire to the frame, on the road a 8:00 am.
75 mile later on I-59 coach start wander in lane very hard to control. We stopped and checked all the tires, found nothing wrong. Then 70 mile later, right rear outside went bang.
We tried to get to a Cracker Barrel parking lot, but ended up on a dead end street with no turn around pulling a tow dolly. So unload the PT Cruiser, unhook the dolly and turn everyting around.
The nice folks at Guardian Credit Union found a tire service to come with a new tire and get us out of their parking lot. Finally back on the road for 85 more miles then BOOM right rear inside
tire blew. 12 miles to exit 4:30 in the afternoon and I'm starting to re-think this whole thing. We made it to Interstate Tire Sevice in Greenville, AL. It cost $1220 for six new tires, plus $215
for the first tire that replaced the flat spare. On the bright side it drives a lot better, the lane wander and bumping is gone. Lesson learned, just because the tires are only three years old
doesn't mean they are good.
The stay in Gulf Shores was great, the trip home uneventful---------We just might do this again.
  • Assuming the date codes were from 2013, age should not have been an issue. A better explanation would be under-inflation for the weight of the coach loaded up for the "long outing". If you didn't weigh the coach after loading and adjust pressures for that weight, then the tires should have been inflated to max sidewall pressure. Under-inflated tires would also explain the wandering. Did you check the tire pressures when the wandering started?
  • Make sure to have the RV weighed and make sure the tires are correct for the load range. If an RV sits in direct sunlight with the tires uncovered and not moved for 3 years the tires won't last. Also depends on the brand of tire, and as some people already mentioned the care of them.
  • In my opinion it is always necessary to replace the tires on any used coach, regardless of how old they are. You have no way of telling the abuse the tires received from the previous owner due to pot holes, curbs, under-inflation, and so on. Better safe than sorry and just figure the cost of new tires in your offer.
  • wantobefree wrote:
    ...Had all tires checked, paper work
    said all six were installed in 2013....
    check ALL of your other tires. just because they were mounted in 2013 doesn't mean that they're just 3-years old. look for the date code on the sidewall. it will be 4-numbers inside of an oval and in the format of WWYY. lets say the number is 4512. that means the tire was made in the 45th week of 2012.
    just because the tires look good doesn't mean they are. rule of thumb that I use is to replace tires after 7-years regardless of their appearance. some folks do it sooner, some later. if your MH had been sitting unused for 3-years I would've replaced all of the tires.
    good luck and be safe.
  • Excellent point on the tires. Thanks for sharing the tires issue and that your problem is solved. Expensive but minor compared to something else that could've happened. Good feedback for everyone.
  • There is always some issue. It could have been a lot worse. Welcome to RVing. Good luck!
  • welcome to rv,ing and you had a easy time with your tires, just think you could have been 300 miles from no where.
