AlaskaShooter
Jan 14, 2018Explorer
I would carry water in the tank, use RV antifreeze in tanks before you leave and check your tire pressure before you leave. With the extreme cold you will loose 1 psi for every 10 degs lower the temp is from when you last checked the air pressure. Then take a tire gauge with you as you head south and check as the temps warm and release air as needed to keep the pressure at manufactures specs. Safes on tire wear and insures proper handling of your rig. When I travel I check the engine oil, other fluids each morning along with the tire pressure when I'm transiting areas of lower or higher temps on a regular basis.
