DSSAMP
Jan 15, 2018Explorer
There is no need to "lower" the air pressure in your tires. They are designed to be aired up to the max on the sidewall when COLD. After driving a while, yes they get hot and the pressure will go up...but letting air out is NOT recommended. The next day when you start out the air will be exactly what it should be as the tires are again cold...seems to be a lot of bad info on times floating around...
38,782 PostsLatest Activity: Sep 10, 2026
