- PeralkoExplorer
Bill.Satellite wrote:
Unless things have changed over the years, the roof of the Prevost is bright white!
Actually our roof is silver-colored. - PeralkoExplorerAnother issue with dark paint is thee checking that have plagued many coaches. While Country Coach probably had the most exposure on the issue, I have seen heat-related checking on just about every brand of coach, including Prevost. We chose a light-colored coach, since we spend much time in the southwest.
- crassterExplorer II
Second Chance wrote:
Back in the '90s, an employee at the Nissan dealer in Augusta, GA, tried an experiment on a nice, hot, sunny southern summer day. He took some test thermometers from the HVAC tech. He placed them in otherwise identical trucks - but one was white and one was black. There was a 40 degree difference in the interior temps between the two trucks.
Rob
Totally believe it. Solar ovens are black. Black metal gets very hot outside on a sunny day. With glass, a black RV with insulation is essentially a poorly designed solar oven. Of course after driving it with A/C it gets much better, but still, I totally believe they are hotter. But let's talk about winter time now. :) - fortytwoExplorerSeveral years ago at the Tampa RV show I stopped at a vendor booth that specialized in replacing the sides of dark painted motorhomes. He said that in some coaches the fiberglass under the dark paint was "toast" in as few as 5 years. Take the handy IR thermometer you use to check your tires (you do use one don't you) and measure the sunny side of dark, beige, and white. It will vary by more than 40 degrees. Something has to handle that extra heat; insulation, air conditioners, or a combination. The laws of thermodynamics have not been repealed.
It's probable that fiberglass manufacturers have manged to change their formulation to survive the extra heat else we would see numerous threads on fiberglass replacement. I would carefully inspect a dark coach over a half dozen years old.
I was lucky to find a pristine unpainted 2014 a couple of years ago. Rare find. It's worth noting however, that white is not a guarantee of trouble free fiberglass as seen in the now defunct Alpha line. - the_silverbackExplorerYes, it does. How many black cars do see in Arizona???
- EffyExplorer IITechnically and from a physics perspective I am sure it makes a difference. But if you buy a decent RV with enough AC's and power as well as decent insulation, I doubt it matters much. I don't see many complaints about darker coaches with 2 or more AC's keeping cool. I am sure if you took the time to measure KW/hour vs a lighter coach you would show an higher KW usage. But let's face it, RV's, especially motorhomes, are a great example of inefficiency to start with. So, it's kind of a moot point.
- dewey02Explorer II
Cobra21 wrote:
Although if you do a lot of fall or cold weather camping, black may be
the way to go! We chose black shingles on our house in Minnesota. More heating here than cooling.
Brian
We're in northern Minnesota and also have black roof shingles. It usually doesn't do us much good however, as the roof is white during the cold weather as it is covered with snow from December through March, and often into April. :( - 10forty2ExplorerPark in the shade....:B
- rgatijnet1Explorer III
msmith1199 wrote:
The Mythbusters did it, but with cars and not motorhomes, but I bet the results would be similar. They confirmed the myth and determined that it got almost 10 degrees hotter in the black car versus the white car.
How many automobiles have 2" of so of sytrofoam or fiberglass insulation? - Mr_Mark1ExplorerI did an unscientific test at a new car dealership a few years ago (BMW's I think). There happened to be a white and a black car next to each other on a hot summer day.
I could not keep my hand on the black car but could on the white.
Safe travels,
MM.
38,783 PostsLatest Activity: Sep 23, 2026
